Working on an office space inside an insulated and climate controlled building. Just one story. Owner wants to consider installing the condenser indoors, above the office area. because the building is already climate controlled, the actual loads are minimal. Another reason for this is the use of a heat pump, in which there are large motor loads in the building so a lot more heat to use inside the building, and temps do occasionally drop below 0F.
So far, total loads in cooling would be around 1.0-1.5T, with heat sources such as computers being more of a factor than the envelope. If a condenser were installed indoors, I'm sure noise will be a consideration.
i realize some might frown at the idea, but in all fairness, a compressor of this size would be about 2HP or less, in which there will be around 100HP min of motors running in the building.
If this is reasonable, is there such a thing as a high seer small package unit that is ducted? I had a ducted mini spit in my head.
