1 - 20 of 32 Posts
11crv
· Professional Member
Joined
Discussion starter · #1 ·
So I was thinking about having the shop order a h10 pro, but seems it is no ether than other at detecting 410a. I watched a couple of YouTube videos comparing it to the fieldpiece slr8. In both videos they stated that the diode in the fieldpiece runs hot. So why couldn’t one adjust the temperature on the h10pro a little warmer to get a similar result as the fieldpiece? I don’t have a h10, but have been researching and arching instruction videos on setting it up.
I talked to Bacharach tech support about my H10G and 410. The tech told me to turn up the heater about 1/6th of a turn when working with 410. And don't forget to turn it back when working with other refrigerants.
Save
Discussion starter · #3 ·
Did the adjustment work for you? My detek select died so I need to pick up a new leak detector this week. I work on mostly residential r22 and 410a.
If it is calibrated right I don't think you would need to mess with the heater for 410 on a new H10-Pro model. You might miss a small leak in auto mode but would be willing to bet the H10-Pro in manual mode is more sensitive to 410 than your Dtek ever was.
Save
It does just fine with R410A. I wish I could compare it with a Fieldpiece SLR8 or H10 Pro. I'll probably pick one of those up soon. I haven't gotten a H10 Pro or SLR8 yet because my H10G does a fine job on 410 with the heater turned up a bit. I've got a couple sharpie marks on the case for my 410 and 22 settings. Just so I don't forget to turn it back.
But remember I that use a plug in H10G. Not the newer Professional. I have no idea even if there is a heater adjustment on those or if it's a good idea. Most guys think the Professional works well on 410 as is.
Sent from my LM-G710 using Tapatalk
Save
Still waiting!!!!Anyone have a comparison between the new D-Tek stratus VS an H10.Both my D-Tek select and new Stratus work well.My understanding is that the New H10,is still using older technology(Not sure if that is correct)I want to try an H10,but only if it is better than the Inficon stratus.
It's been done. If you want ultra sensitivity to small leaks it's the H10-Pro.
If you are hunting in a saturated space ppm looks helpful and the sensor won't get eaten up.
Save
I have a Stratus and D-tek select.Going to get the H10pro in the next week or so.Trutech tools has a good price on it,considering it is about $525.00 -600.00
Get the H-10. Be very careful to never suck water I’ve killed the pump motor and sensor on one by being on the phone and not paying attention to what I was doing.
I made that mistake too, luckily when I took it apart that night I found I just had to dry out the filter inside the pump motor and clean out the hose. Happens pretty quick though.
Save
I wonder if it would be interesting to fit a small coalescing filter in-line right after the wand, that would be an easy way to prevent too much liquid being sucked inside the unit.
FYI
Learn about Refrigerant Leak Detection, it's applications and best practices with TruTech and Bacharach this Wednesday 6/10 at 7PM EST
Plus! Stay through to the end for a chance to win a Bacharach H-10 Pro!
Sign up here: https://us02web.zoom.us/webinar/register/WN_pzZ6UL2OTXe8j8_g4o3BcA
New H10 pro;I got a new H10 pro yesterday,Charged up the battery.Turned it on!!!I think I'm getting a tattoo!!!This leak Detector Is Very loud!!!Is this normal/I have not used it in the field yet!!!BUT is this working properly.Not used to such a loud leak detector.Is this normal, or do I have a bad one?
Yes. It's very good a detecting small leaks. Every single other thing about the detector sucks!
Should be quieter in the Small setting vs Medium or Large.
Save
1 - 20 of 32 Posts
