1 - 14 of 14 Posts
tarheel_tech
· Professional Member
Joined
Discussion starter · #1 ·
Went on this no heat call today.Installer would not return their calls.(Wonder why?)Can't see it all that well,but the unit is setting on bricks on the 4 corners of the unit instead of an pad.To work on this unit,you have to stand in a puddle of water.Really good idea working with electricity.:rolleyes:Disconnect mounted to the unit which I have never liked.Unit not sealed properly to house at all.Outside cover attemted to be sealed with a can of great stuff foam.:eek:Not even attempted to seal cover to the unit at all.Gas line leaves alot to be desired as well.All in all it is a typical low bid install.Here are the pictures and see what everyone thinks.http://picasaweb.google.com/ChrLBrann/GotADealForReal2?authkey=CB8_9bvmpHk
Save
now you broke the spray foam seal
You reallly shouldn't have taken a leak by the drain line
Save
Discussion starter · #12 ·
Save
Look at the brand! Coincidence? :rolleyes:
Goodman GPG junk. Condensor fan is probably vibrating the top like crazy. Better keep spare blades on your truck if you work on them a lot, the rivets fail on the stock ones. At least Goodman realized recently that maybe it's a good idea to pack the replacement blades in boxes, not stacked 10 high.:rolleyes: The good news is the indoor txv is a breeze to change after recovery.
1 - 14 of 14 Posts
