This is my first time writing here, I hope I haven’t broken any rules.
The furnace is Goodman, model GMVC950453BXBA, assembled in USA 06/12/13
About 2 months ago it started not working properly. The thermostat showed that it was working, but in fact it was not. I turned it off and on several times. It started working (I heard a sound) then stopped after about 30 seconds, but the sign was that it was still working. I realized that these 30 seconds of “work” were the work of the fan, but there was no ignition. Then it worked fine for a while. Then everything happened again and I decided to invite a technician. He checked everything and said the problem was the low pressure switch. He ordered it, but when another guy came in a couple of days later to change it, he saw water dripping (furnace was working again). I took the photos the next day when it was dry, but showed the areas of dripping and you can see the salt marks from the drying water. The technician said that the water was not coming out of the tube and it was a problem with the inducer motor, but due to its price, the best solution might be to replace the furnace with a new one. He suggested the Carrier brand (of course they work with them) and noted that Goodman-Amana furnaces are not good at all and leaks like this are a very common problem. Sorry for the long story.
The questions are:
Is it really not possible to repair an inducer motor?
Is it really better to install the new furnace rather than just replace just the motor?
Is Carrier really better than Goodman-Amana?
Is ten years normal for a furnace? I actually hoped it would last at least 3-5 years longer.
Appreciate your help in advance.
Thanks a lot.
The questions are:
Thanks a lot.
