OK. So I don't clutter up the wall of shame with repeat posts I'm going to keep posting similar posts under this one all having to do with the repeat failures on Goodman JUNK out here on the West Side of the Valley that we like to refer to as GOODMAN COUNTRY!
Where Goodman's are installed 9 to 1 out of any other brand in these blow and go track homes.
Like I mentioned in another thread, I repair the same stupid failures on Goodman's every week.
1)Stack Relays
2)Cap Tube Leaks
3)Compressors
4)ID Blower Wheel, motor mounts, etc
Sure every brand has it's problems. But when you fix the same problem in many homes all in the same track, that's pretty sad!
Here's what I did today in Goodman Country.
I replaced 4 stack relays today. I used all of my Honeywell Fan Managers that I carried on my service vehicle. I NEVER install a stack relay back in unless the H/O absolutely refuses to let me install a REAL fan relay.
I wish I could change the pictures size in my posts like you can when img src= commands are allowed in other forums.
1st call Serial number 9811****** I RARELY see a stack relay last THIS long.
I throw the stack relay out into the street (not really) and install a Honeywell Fan Manager. I also always splice in a 5 amp fuse into the secondary of the transformer. Why Goodman doesn't fuse that, i don't know.
2nd call. Sorry the flash made it WORSE. serial number 0201****** That's a 2002 unit. Most of the stack relays I find are 2 to 3 yrs old.
While I was up there I cound't miss how well they mounted the drain trap. WOW. How is THAT going to hold water.
So I fixed it real quick.
3rd call today. PHK048-1 serial number 0109****** A 2001 unit. Another bad stack relay!
Again I swap in a real relay. The Goodman package units are not too bad if you were to (on every unit) seperate and silicone every cap tube assembly, replace stack relay with a REAL fan relay like a fan manager, add extra screws into the fan shroud (that WILL warp and buzz like a chain saw) add a comp noise blanket, make sure the blower has a STRONG enough motor mount. Then I'd leave it on MY home.
6th call of the day (actually had 2 that were NOT the top breakdowns to worth post). ANother bad STACK RELAY. AR36-1 serial 0110****** (home was finished in april 2002)
Again. I swapped in for a fan manager.
My 5th call of the day was like this.
Goodman uses weak spade terminals on their comp leads at the comp. Then they get lose and burn the wires.
However, thse old condensers (like this 1993 model) were the best of Goodman. I mean they were GOOD! Better than alot of other brands newer stuff in my opinion. Compressor was behind the metal panel NOT under the OD fan. They were QUIET. All components were EASY to access. No rubbing cap tubes, etc.
Why did they change them to the sh*t they use today?
That was TODAY's Guaranteed Goodman breakdowns.
Tomarrow if I work in GOODMAN COUNTRY I'll post more here.
Wait to you guys see how often the SAME thing goes wrong on these things here in Phoenix THEN tell me what you think!
1)Stack Relays
2)Cap Tube Leaks
3)Compressors
