1 - 2 of 6 Posts
Put fan switch at thermostat to ON from auto setting, the blower should run 24/7 independent of the heat or cool, then run your A/C to see if it happens ( blower shutting down ) either way if the blower stays on then run your A/C until a experience Tech. can check your system.
Hopefully your system got registered, as manufacturers warranty decreases significantly if never registered.
Save
I did ask the installers if they were registering the system since the Goodman compressor is warrantied for life. Indeed in times like this, I wish I would have just done it myself.
Check yourself, need the serial numbers of each piece of equipment they installed. Guessing you have the GSZC16 as that model has the limited lifetime compressor warranty, once registered to original owner. Looks to also have ( at least the 2020 models ) have a whole new Outdoor unit if compressor fails within the 1st 10 years, once registered to original owner and a 10 year parts warranty including coils. Now if your system was never registered chances you have a bare bone 5/5 compressor, parts and coil warranty.
https://www.google.com/url?sa=t&rct...url=https://www.goodmanmfg.com/warranty-lookup&usg=AOvVaw1gJ1uW-zrXekNqLQUUgIov
Save
1 - 2 of 6 Posts
