1 - 1 of 16 Posts
1) Is it the case that a single heat pump could reasonably replace three major pieces of equipment (furnace, A/C, and electric heat pump and air handler in the attic)?
Yes. A typical heatpump includes an airhandler, indoor coil, secondary heat (electric or gas furnace) and an outdoor unit.
2) Whenever a homeowner posts a geothermal thread in this forum, the discussion seems to devolve into a handful of homeowners talking amongst themselves and comparing notes.Iis the professional support for installation and design so thin that this accounts for the lack of input and the high prices in our area? Not a complaint, but just wonder why such a small percentage of professionals have much to say (one way or the other) on the topic of geothermal HVAC. I could find a hundred conventional HVAC residential contractors in the yellow pages in a minute, but I really have to work hard to find geothermal installation/design people, especially for residential applications.
There are probably 100 air/air units installed for every single geothermal unit. The biggest single issue is cost. I love a Mercedes, but I drive a Chevy. Because there are so few installed, you need to find a "specialist", someone who has installed several already and is familiar with the equipment and function. Since it's a specialty, you can bet it costs more.
3) For those professionals who want to comment, what lines of equipment are recommended for residential HVAC? I am looking into Water Furnace, Climate Master, and Honeywell.
I cannot make an educated comment on this.
4) Are the energy savings of 50-70% that are flacked by the geothermal proponents really on the mark, or not, in your experience?
Air/air systems are far more energy efficient than they used to be. Some of the geothermal systems fail to include the energy costs related to pumping water. However, if you compare apples to apples, a geothermal system is typically more efficient and more comfortable than air/air.
5) If cost were no object, would you install a geothermal system in your home, or not? If cost were an object but you wanted it, which systems would give you the most value for the buck spent? If the efficiency of geothermal heat pumps is so great, is it still important to have multi-stage compressors and variable speed motors for air handlers, or is this a shortcut to contain cost that you could recommend? Or is the dehumidification issue pretty much the same as for conventional systems?
If cost were no object, I'd have a geothermal system. But I'd also be dating a supermodel.
You can always add more bells and whistles. If I was gonna spend the bucks on geothermal, I'd spend em on a top notch system with all the bells and whistles.
6) Do you buy the premise (or the promise) that the geothermal heat pump will have a much longer life span than an outdoor unit, since it is inside the house and not subject to the elements?
Yes. A closed loop water system is an important element of this premise.
1 - 1 of 16 Posts
