Furnance within door within garage
785 views 16 replies 7 participants last post by  minus2x4
#1 ·
Hi. I'm thinking of renting a place that looks nice, but one thing concerns me. The furnace is inside a door within the garage. Now, from research, it seems this could be a bad idea if the furnace is gas or your car is ran in the garage, but everything is electric in this case and no cars will be in the garage. My main concern is if the air quality will be worse because of the air quality in the garage compared to indoors. I attached 2 pictures to show. The first is the door to the furnace in the garage on the left. All the stuff there will be gone if that matters. The second is inside the door.
#2 ·
Thread moved to AOP Residential. This is the only forum where homeowners may post.
Please take not of the new location.
Save
#5 ·
But this unit doesn't heat / cool the garage space, does it?
As it is electric it does not take combustion air from anywhere either.
From the air ducts pictured the conditioned air flow appears to be isolated from the garage space.
So your concerns would seem to be unfounded.
PHM
View attachment 887491 View attachment 887493
  • Like
Reactions: vstech
Save
#13 ·
Hi, pecmsg. Can you tell me what you mean by close in the garage door? Also, the door where the furnace is is on the left, were you asking about the opening on the right? That's the laundry room, but yes I would always have both doors closed and no car in the garage.
#15 ·
I grew up in house that only had Dearborn unvented space heater. I was probably was expose to over 50 PPM CO. If think about it, even starting your car in garage with door open you still can be expose to CO. It's not enough to harm you.
#17 ·
Thanks for the replies, well I got a Forensics Detectors CO meter just in case. Also, what is the best way to seal this portion along the small rectangle on the left? I got this fog pencil and was noticing leaks in that area. Also, seems to be below that too but that's the air filter door, so maybe I should seal that too?
