Hello, newbie here and hoping to get some guidance here.
Background:
Have a Single Family home with a 4 ton furnace for heating - Payne PG8JAA048090AEJA. We recently changed all our original 50 year old metal ducts (also did asbestos abatement) to newer flexible ducts (for supply only). Ever since then, we have been having furnace short cycling issues - furnace turns on, stays on for about 4 to 5 minutes, shuts off and starts back up in about 4 to 5 minutes - when the furnace shuts off, our Google Nest gives a "Power Out" error. The home eventually heats but is less efficient than it could be. On consulting with a couple of hvac companies, they mentioned the air return is the issue and furnace is overheating tripping the limit switch. The solution proposed is enlarging the air return and/or replacing the entire furnace. One even recommended operating it without a filter (this did not help and same issue persists).
The dilemma:
While the HVAC contractors say air return is the problem, they have not provided any actual data on if this is really the issue based on any measurements. We purchased the house in this condition and never had this issue with the metal ducts. One HVAC person mentioned that newer flex ducts are more efficient and now the supply air is more so the return sizing needs to be adjusted - I find this hard to believe without any actual data. Also, statements like "increasing air return size may help but not 100%" do not instill a whole lot of confidence that this is actually going to solve the issue.
Some additional information:
We have 13 supply ducts in the house and 2 return ducts - supply registers are in various rooms and the return ducts are only in our living room and passage area. Unfortunately no easy option to add more returns without heavy cutting into drywall, patching etc. - this will be quite labor intensive and cost $$$
Is there any way to go about gathering some data on if return airflow is indeed the issue? Something like the system is currently supplying 'x' cfm worth of air and return is only returning 'y' cfm - so we need to compensate by 'z' to make supply = return? This would atleast make logical sense and be more convincing vs the hvac pros just mentioning air return is the issue. No one has been able to give any convincing solution while we continue living with this issue. Not sure if cleaning return ducts and our exhaust vent would be a good first step before additional work.
Any help or guidance on this would be really appreciated. Thank You
Background:
The dilemma:
