Hi Pros,
I am a new homeowner in the coldest State in the United State, Minnesota. My furnace is located in a CLOSET at the basement. There are three fresh air supply in that closet and I cannot manage to make our basement warm with all of these cold air intakes.
I was wondering if I can block the 3rd fresh air duct that is illustrated in the attached image ?
First fresh air supply is for Combustion Air Intake
Second fresh air supply is the duct that is connected to the return air supply of the furnace
Third fresh air supply is loose on the closet floor.
As you can see I have already blocked the 3rd fresh air supply but people keep telling me that it is not safe and I don't understand why. Some people telling me that it is not cost efficient but I have smart thermostats and it shows me I well run the furnace less frequently when the 3rd fresh air duct is blocked. I the duct into a bin and make the output shape like J but there was little or no impact.
There are only two hot air vent in the basement ceiling. In order to make the basement warm I have to close almost all upper level hot air vents to force most of the hot air come out from the basement. However, this 3rd fresh/cold air duct is just messing with the hot air right in the basement and does not let the hot air even warm up the basement.
The AirCycler does not control any vents. I believe all the vents are always open. AirCycle control just let me turn the Fan periodically. Something that my smart thermostat can do as well.
This is a fairly new house built in 2007 and it is very air tight. Infact I put some 3M window seals on the basement to even make it more tight.
