Hello everyone. I would like to thank anyone upfront for any insight you may be able to provide.
I live in New Brunswick Canada and recently had a Sharp THU 12,000 BTU ductless mini split installed (rated to minus 27 celcius or minus 15 F). The unit has worked well until recently.
Two weeks ago when it was minus 13 celcius (or 8 degrees F) suddenly the indoor unit went into defrost cycle and would come out for about one minute blowing a small amount of warm air and then return to defrost cycle. It would just repeat this over and over again with the house temperature dropping from our set point of 72 F to 65 F (this took 4 hours).
So I flipped our circuit breaker and turned the unit off (waited 5 minutes) and flipped the breaker back on and turned the unit back on and this seemed to "wake" the unit back up and it started to work again.
It even worked perfectly through a real cold snap where the temperature fell to minus 25 celcius (or minus 13 F).
Then on this past Sunday I woke up to the house cold again (it was only minus 13 celcius...8 F outside). The unit had once again returned to the repeated defrost cycle thing again.
Couple of points:
1) There is no frost on the outside unit when this happens (the Sharp THU comes equipped with a heating coil and large drain holes so there is nothing clogged)
2) No snow covering the unit.
3) The unit was installed by a reputable HVAC company who is coming to look at it this week.
I am asking the questions here more or less so that I have some insights so that I can ask educated questions. The technician I spoke with on the phone more or less said he had no explanation for this.
Any help?
Couple of points:
Any help?
