Live on cape cod. basements are notoriously damp and musty around here. I have owned this house for about 18 months. The basement is poured concrete, about 1,000 square feet, with about 2/3 of that finished space and the other 1/3 storage/mechanical/etc.
When I bought the house, the basement was damp, but not wet. It had a musty smell but on a scale of 1-10, I would give it a 6 at the time of purchase, which is much better than average around here. They had one of the walmart special dehumidifiers running...the type that costs $150 and needs to be manually emptied and always freeze up when not summer time.
I installed an Aprilaire 1830 dehumidifier after a lot of research. I have it set up so that it circulates the air all the way through the basement (expels dry air into the finished area, air intake into the unit is from unfinished area, circulation vents between the two spaces). I have the humidity level set at 45% RH. It has a digital hydrometer read out and does an excellent job keeping the humidity at the set point. Since install, the air never ever feels even remotely moist. It runs a lot when it is humid outside and only occasionally when it is dry out. I have high confidence there is very little moisture in the air...the only downside is that when it is running a lot, the basement gets hot. I also added a Whirlpool WPT80 HEPA air purifier.
I was hoping this would solve the smell issue and get it down to a "1" on a scale of 1-10. It definitely helped...I would say it brought it from a "6" to a 2 or 3. I am sensitive to the smell of mold (or whatever that musty smell is), so I was ok with this but still a little disappointed. Well, recently we were away from the house and had the basement totally closed up for 7 weeks. Both the air purifier and dehumidifier were running the whole time. Wow...went from a 2/3 to a 5 I would say. There goes the big improvement. My kids like to play in the finished area (they never seem to mind the smell and my wife thinks I'm just being picky as she couldn't smell it after the fixes and thinks it's OK now).
I want the musty smell gone! I'm torn between how to get there. Here is what I'm tossing around as next steps:
-Bigger air purifier
-Add an air exchanger (ERV???)
I'm not sure if the increase in smell is more due to the stagnant air (nobody going into the basement for 7 weeks) or maybe the HEPA air filter on the purifier just needs to be changed? I do not mind spending the $$ on solutions that will work but do not want to throw money away.
I also want to add a mini split (more to address the heat in the summer than anything but would also be nice for reverse cycle heat in the winter as the basement has electric heat $$ now), but I guess that is another topic.
What do people think the best next step is here? Replace HEPA filter? Replace air purifier with something much bigger? Add an air exchanger (what kind?)? Something else?
THanks for any input!
