If I've got a water cooled chiller and all of my piping is inside in conditioned space - do I need any glycol in that loop?
is any of your piping going to air handling units? if yes do they have economizers or fresh air intakes? if any of the previous applies, then yes you must use glycol.If I've got a water cooled chiller and all of my piping is inside in conditioned space - do I need any glycol in that loop?
I think you mean cooling coil is downstream of the heating coil. Otherwise, how do you have freeze protection?Cooling coil is upstream of the heating coil for freeze protection as well as dehumidification, I always call for my units to be oriented that way even if there is no application for dehumidification.
SorryI think you mean cooling coil is downstream of the heating coil. Otherwise, how do you have freeze protection?
Design temp for Chicago is -10 and we've hit it more than once this year.Wow, hvac consultant, must be cold up there to have two heating coils in a row! In DE we have a lot of humidity, so especially in Industrial Apps we'll also see a fair amount of PH CC RH as well.
PH for protection and extra heating, CC to cool the air down and condense the moisture out, HC to heat it back up. with CC before HC, you get dehum.As far as the preferred setup with PH > CC > HC, I can't say I've ever seen a unit installed with this configuration. I don't see many preheats, and they are usually very old & done with steam, but they are always PH > HC > CC in my observances. Just wondering why you think that is the preferred setup?
