Central FL area (humid subtropical). A family member is in a new construction home with a production builder. Blower Door result of 1.93. Originally, no fresh air intake, just a 100cfm bath fan in the attic.
After questioning, the builder added ventilating dehumidifier. However, the dehumidifier can't get below 60%, set to 45%. The heat pump is set at 78. The dehumidifier does not seem to be changing the humidity level in the house at all, despite running for over a week.
Installer says to use the Heat Pump to cool to 73 to dehumidify as the dehumidifier won't go below 60%. This doesn't seem right. The system is producing very little condensate.
What to check, or is this normal?
2k square foot home CMU Block, encapsulated spray foam attic, ductwork in conditioned space.
Broan B120DHV 120 Pint Dehumidifier
