We are building a 4800 sq. ft. home with divided living spaces (generational home / elderly parents on one side, immediate family on the other). We have two master bedrooms, two kitchens, etc. We had planned on two traditional forced air systems with separate thermostats, originally located in a crawlspace. However, after seeing the cost of the crawl space, we thought of removing it from the plan, but in doing so we will have some challenges in bridging some of the vaulted ceilings where there is no attic space above. Some of the ideas suggested seemed kind of unsightly to me. This involved a self-supported duct bridge across the area that says light-well in the plans. I wondered if there was another way to overcome this situation -- such as with a ductless system. When I suggested it to my GC, he felt, while theoretically efficient, the individual units / zones would not provide enough heating in the winter. He suggested a zoning system with dampers as another option.
So…what about a ductless solution? Do people choose to install mini split systems (Mistsu Mr. Slim, Fujitsu Hybrid Flex Inverter, etc.; Daikin is not availably in my area) in new construction? I have seen lots of discussion in remodel / old construction applications, but not too much about new construction applications.
What about other solutions? I am all ears...
Suggested systems we were planning to install is:
1 RUUD 90K BTU, 4 ton, 13 seer
1 RUUD 60K BTU, 3 ton, 13 seer
A heat pump upgrade was optioned.
Any thoughts would be appreciated.
