Cost effective to rebuild draft inducer blower?
8.6K views 25 replies 11 participants last post by  GT Jets
not to sure about this inducer but most have oil port front and back of motor and need to be oiled each year. If not the bearings tighten up and will cause the motor to over heat and burn the windings. If yours needs to be oiled and you are not doing it then you will get about three seasons out of it. If it is sealed bearings then you have other issues and need to have it looked into. The rings on the HX need to be checked also
