Your comparing applea to oranges my friend...they're not the same.
Dear Thehumid1,
Regarding your previous post to TWCpipes:
I agree with 99% of what you said in point one of your reply to TWCpipes. You in fact, never said the outside temperature doesn’t drop below 60 degrees F, you actual said the outside temperature does drop below 60 degrees, but only for a few days out of the year. What I wanted to point out was that you stated that Serverroomcooling could simply open his window in the Server Room when it was 48 degrees outside, install a fan, shut off his A/C, and get the room down below 65 degrees F. Although I know you were only kidding, I’d like to point out, if memory serves me right after viewing the photos that he posted, that this is an interior solid un-openable window adjacent to another interior area of the building, and therefore wouldn’t work under those conditions. Like I said, a small issue only, say…..1%....lol.
I do have to point out one thing regarding point two of your reply to TWCpipes though. This project is NOT “residential cooling” in nature. It IS “process cooling” in nature. That one distinction means the following:
1. Process HVAC systems capacity requirements are designed on “worst case scenarios” in terms of outside temperature and humidity.
2. Process HVAC systems operating priority lists energy efficentency below operational ability under all outside conditions.
In other words, the HVAC system must be able to work under all “foreseeable” scenarios, such as the occasional hot, cold, humid, or dry weather conditions. And yes, although you made fun of it, emergency stand by generators are required at some process cooling sites.
In addition, the HVAC design engineer, installation, and service personnel that work with these two different HVAC systems must poses different skills, abilities, knowledge, test equipment, and experience in fulfilling their duties in dealing with these systems.
That’s not to say that the basic refrigeration cycle is different between the two systems, it is not, but it is to say that the application of the basic refrigeration cycle to the particular process cooling system can be totally and utterly different.
In conclusion, residential and process cooling systems are two entirely different types of HVAC systems that have different priorities and functions when it comes to their designs, installations, operation, and service. Therefore, although some people may see similarities existing between the two, comparisons of the two should never be made.
Respectfully Submitted,
John J. Dalton
