I always throw away the single pole and go with a two pole on residential and move both CCH wires across L1 and L2. The cost difference isn't a big deal between a single and double. As for commercial that is a different story, to go from a two to a three poll can sometimes be a substantial jump in cost. I would usually stay with a two pole over upgrading to a three pole for this reason, unless for very specific reason. Also these EURO style contactors I am seeing seem to have some exaggerated ratings, IMO, they have very small contact pads in comparison with your plain old contactor that have a bit more meat in the same rating. And older contactors from the 60's, 70's, and into the 80's were much larger with larger contact pads compared with present day contactor of the same rating. Getting to the point with some of these older contactors that there are no longer contact replacement kits, as I go to replace it, I get a contactor half the size, with smaller lugs, and really garbage in quality when compared to the old.
As for that Emerson SureSwitch, I can't remember the year, maybe 2010 or so, I was at Johnstone and the rep gave me one. Fast forward to this last September, I decided to lay a large cement pad down to cover the embarrasing desert area of the side of my home I gave up trying to grow anything. I had to remove my AC. Not a big deal, only a 20ft line-set and AL finned-Copper tube condenser, so I thought it a breeze to just throw the gauges on, push in the old contactor, suck her on down, valve off, ....EASY PEASY... NOPE, I totally forgot that I installed this mystical box...LMAO, there is NO WAY to think around this damn thing to pump down a system in a conventional way. Ended up wire nutting the LINE and LOADs together and used my main disconnect there...100psi , 90, 80, 70, 60, 50, 40, 30, 20, 15, hurry close suction before in vacuum...10psi..sweet...Pull Disconnect!...whew. As for how the mystical box works and if it is any better and how much more life I will get out of it, I do not know, so I can not give it any ratings other than it works and has been working for a decade. Nothing internal you can look at without breaking it to judge arcing, carbon build up, etc.
