Does any one know how come a contactor is welding shut with in 3 to 4 months. Replaced it twice. It does have a mercury bulb or bimetal T=Stat.
Replace stat with digital, that will limit the amount of cycling.Does any one know how come a contactor is welding shut with in 3 to 4 months. Replaced it twice. It does have a mercury bulb or bimetal T=Stat.
My question is how could it not be load related ? It takes amps to weld. I have seen plenty of chattering contactors not weld shut. Pit them up nice though.but I doubt it is your loads.
Check the Heat anticipator on the stat or just change it to digital.Does any one know how come a contactor is welding shut with in 3 to 4 months. Replaced it twice. It does have a mercury bulb or bimetal T=Stat.
How does changing the heat anticipator setting affect the amount of cycling the contactor does in cooling mode?Check the Heat anticipator on the stat or just change it to digital.
Should have said cooling anticipator if applicable some have them some don't but it sounds like something is causing chattering, could just be no time delay and an out of calibration mercury bulb stat or something completely different.How does changing the heat anticipator setting affect the amount of cycling the contactor does in cooling mode?
Now have seen 4 welded shut, regular 2t to 5 t and the start amps seem the only reason, and OEM maybe out of 100million produced, etc...It could be Ants,....drawing 18 amps on a 35 amp rated contactor is not going to weld it shut. He has points becoming very dirty to the point they weld.
Space shuttle is retired, so I'm going with the giant toaster....A TDR in a stat does what when the voltage is lower then 18V or a switch is cycling?
A TDR in the unit at the contactor handles both. Make it a DOM and there will be no conflict with the stat built in TDR.
I am going with a crap contactor not seating properly on this one and/or amps due to start up/low line voltage.
These contactor troubles are on a giant toaster or the space shuttle?
Might help us to know, just sayin![]()
I'm thinking a 17 phase toaster as wellSpace shuttle is retired, so I'm going with the giant toaster....
