Is a condenser pad necessary on top of a concrete slab?
If that is code then yes it is required. Now we can argue all day on the validity of the reason for it but if required The Powers That Be win.In our local if the pad is in direct contact with the foundation then an equipment pad is required
Spread the weight around on the concrete so it doesn't crack.��
A padding direct contact and a pad required?
I'm confused
Key words “if that is code”, some inspectors will make up their own codes and when you ask them to show you where it says that, they can’t. Not worth the argument for some things but other times the argument is warranted.If that is code then yes it is required. Now we can argue all day on the validity of the reason for it but if required The Powers That Be win.
