What do you guys use to clear out a condensate drain? Is there an easy way?
Those EZ Traps are nice. I just swiped the brush that comes in the kit and stuck it in my tool bag. A nice round bristled brush made just for 3/4" pvc on a 18" flexible shaft.If its really bad or a chronic problem you might want to consider an E-Z trap that has cleanout points built in to it.
You mean lazy a** guys.The old school guys normally use R 22 to blow out condensate lines & pressurize line sets -- extremely foolish
Do they have a lot of power, I want one but was unsure of the power of themI agree with the last post the best and safest way is to suck it out with a wet vac those battery powered dewalts rock because they are so portable.
Or in a wall cavity.Pressurizing a drain from inside is seriously bad mojo.
Until you've blown a poorly glued joint apart in an attic or in an air handler plenum... you just haven't had a good day.
The power is proportional to both the pressure you apply & the additional water you put in the drain pan. The source of power is either nitrogen or C02, it pulls a venturi effect on the drain. Certainly a shop vac has always been a good tool, but when you look at stringing extension cords & lugging it around - this is superior in ease of use & performance. We found better "cleaning" of the drain as the water still in the drain, plus slime & debris (plus chemical agents you can pour in the drain pan) all act as a physical ram to move garbage along vs the old nitrogen blow out that only proved to punch a hole in the softest area of the blockage resulting in call back after call back once even the smallest amount of slime made its way down the drain.Do they have a lot of power, I want one but was unsure of the power of them
I have used one of these before, I was wondering more about the DeWalt Vac. Thanks though, Good information about it.The power is proportional to both the pressure you apply & the additional water you put in the drain pan. The source of power is either nitrogen or C02, it pulls a venturi effect on the drain. Certainly a shop vac has always been a good tool, but when you look at stringing extension cords & lugging it around - this is superior in ease of use & performance. We found better "cleaning" of the drain as the water still in the drain, plus slime & debris (plus chemical agents you can pour in the drain pan) all act as a physical ram to move garbage along vs the old nitrogen blow out that only proved to punch a hole in the softest area of the blockage resulting in call back after call back once even the smallest amount of slime made its way down the drain.
Note of caution -- watch where you aim it, you're about to blow a snot ball across the parking lot.
