Alright so I bought a broken KitchenAid Fridge (kfcs22evms4) from someone, they told me the technician said there was a leak which is why they were getting rid of it. I checked for leaks and couldn't find anything. Figured out the low side was going into a full vacuum so I isolated the cap tube (which was completely restricted) and purged it with 300 psi of nitro until what looked like some oxidation came out the other end. I decided to flush the cap tube with one of those flush canisters and ac flush until there was an uninterrupted stream at the other end then purge with nitro afterwards.
I reassembled the the cap tube, installed a new filter, triple evac, and weighed in a new charge. Checked to make sure the low side wasn't going into a vacuum and let the fridge cool down. After about a day temps were still in the 40 degrees range, checked the gauges once more to find out the low side was around -15in. Hg with the high side at around 120 psi. So no doubt the cap wasn't completely blocked but is now slightly restricted.
What are my options here? I cant find the size and length of the existing cap tube anywhere to replace it and I don't know what else I can do to try and free up that restricted cap.
