Can any one tell me what can be the reason of low suction pressure in York chiller model YCAA-B-170. After descaling the three BPHE COOLER of the three chillers they runs for one month with healthy suction pressure 65 to 75 psig, but slowly one by one the chiller suction pressure starts getting low, now it's goes up to 35 to 45 psig. This chillers are used for cooling air compressor systems. There is no water flow in and out is given on cooler, but instead given on chilled water pump discharge going to air compressor heat exchanger and the warm water coming back to chiller in main header. The pump discharge water is showing 37 psig and chilled water inlet header pressure to inlet of cooler is showing 10 to 12 psig. The chilled water is treated with anti freeze coolant. The reason for descaling cooler was scale formation as it was tripping on antifreeze thermostat. After descaling the problem was solved, but after one month it starts lowering the suction pressure. For your info, the outlet of chilled water goes to 5000 liter of insulated water tank, and from tank the chilled water goes to suction of pump, the suction line filter of pump is also checked foun clean. But still problem not solved the flow of water on flow meter is same healthy as usual i.e 129 gal/min. Please guys your comments please if any body face similar problem.
