It is an electric heater. I don't know much more about it.
A little more background:
About 6 months ago I bought z-wave Honeywell Thermostat. I didn't realize that this was a professional install only thermostat. I was able to install with help from Honeywell. The air worked fine in the summer and the heat works fine in our downstairs, the upstairs is just not as hot as it should be I think.
All the vents in the upstairs are putting out around 78-79 degrees.
I have the system type set on the Honeywell thermostat to #1 (1 heat/1 cool conventional). Is this the type of system I have (can it be determined from the attachment)?
1 1 heat/1 cool conventional
2 1 heat/1 cool heat pump (no aux. heat)
3 Heat only (2-wire systems)
4 Heat only with fan
5 Hot water Series 20 system (power to open & close zone
valves/normally open zone valves)
6 Cool only
7 2 heat/1 cool heat pump (with aux. heat)
8 2 heat/2 cool multistage conventional
9 2 heat/1 cool multistage conventional
10 1 heat/2 cool multistage conventional
11 2 heat/2 cool heat pump (no aux. heat)
12 3 heat/2 cool heat pump (with aux. heat)
