Looking to replace my very old central A/C unit. I got a few quotes and i think i narrowed it down to these. I am still undecided between and undecided if i should replace with a ducted heat pump or just do the ducted A/C replacement. I have a newer boiler so i'm covered heat wise but since they say the heat pumps are more efficient for cooling. The heat option sounds like it would be a nice to have option and is only a couple thousand more. I'm in NJ zone 6/7.
Option 1 (A/C)
Daikin 4 Ton 15 Seer DC5SEA4810
Optional replace metal supply trunk and all flex lines with R-8 Ducting ****
(***** total including replacing ducts)
Option 2 (A/C)
Rheem 15.2 Seer RA1342NZ
Option 3 (Heat Pump)
Daikin 4 Ton 17.5 Seet DZ6VSA481E
Option 4 (Heat Pump)
Bosch 5 ton 20 Seer BOVA-60HDN1-M20G
Option seal existing duct work and wrap with bubble duct wrap ****
(***** total including sealing/wrapping existing duct work)
Please do not add pricing to your posts as it is not allowed by forum rules - thanks.
Option 1 (A/C)
Option 2 (A/C)
