Got a unique intermittent issue.Customer stated fan going on\off rapidly,and no heat every 7 or 10 days.I found broken door switch, barely hanging on.Replaced,start Her up,was about to leave-inducer starts going on/off,then turns slowly,then On/off,On/off.I run out to my van for a Meter,come back in,flip the switch on,inducer runs normal.Put on amp Probe,trying to catch it losing power.Noisy,draws 2.1 on Hot and 2.8 on neutral,rated for 2.6 RLA.But runs normal,proved a draft and fired.Could be bad relay on Ignition Board,got 120 to motor. I would think it's the Draft Motor with those reads.Never had a board be Intermittent.York,TG90809S.Any advice appreciatediated!Ran it for an hour, couldn't repeat the condition.
