I'm new to this whole system, so may get terms not exactly correct etc.
I just bought a Carrier Multi Zone Ductless system, the performance series. I've got a tri-level house, with one high wall unit on each floor. A smaller unit in the family room and "master" bedroom, and a larger one on the main floor.
My question is in regards to zoning. I previously had a Cub Cadet style heat system, and about the only thing that was good about it was that each unit was totally independent. Want a room colder, turn it down.
My new system is working great, toasty warm in here, and the constant air circulation has eliminated the cold spots we used to have. With the family room unit at one end and the main unit at the other, heat is pretty even throughout the house. (Master is in quotes, as it's a small room and a modest sized house)
My problem is the upstairs bedroom. There are no doors between the levels, so air flows freely. That caused what I called the "waterfall" of cold air coming down the steps. That's no longer an issue, but heat is flowing upstairs pretty well.
I was lead to believe that each unit would be it's own zone. I've got the upstairs set to 68, but that's doesn't matter. It's 75 up there, and when the other two units are getting heat, that one does too. The fan only runs on low, but it's still heating.
After talking to the installer, who in turned talked to his tech, it appears that when one unit gets heat, they all get heat. The only "zoning" is how fast the fans blow, with the colder ones blowing faster. But it appears the only way to stop the fan in the bedroom is to turn that unit off completely. I guess it still gets heat even then but since no fan is blowing, it's not as bad.
I was of the impression that each line had a valve or something, and only pulled heat when needed. It appears I was wrong, and the refrigerant circulates through them all, and when the heat is on, it's on at all of them?
1) Am I understanding this correctly?
2) Any solutions, other than to turn off the upstairs unit entirely? Normally I like the fan running to move the air and keep temps even but I wish there was a way to tell it "If you're above temp, and the heat comes on, turn OFF the fan until the end of the heating cycle."
