My 18 year old A/C Trane XR11 has a slow leak (R22) and I need to get a new AC. Furnace is the same age and is a Trane XR80, it isn't having any issues at this time but wanting to just go ahead and do both to take advantage of the electric company HVAC rebate which I found out would require both the new AC and furnace to be compatible to achieve the AC's stated 19 seer2 rating on the AHRI certification. Both contractors said I would not get that 19 seer2 rating with my current Trane furnace. I've gotten bids and have narrowed it down to either the Carrier Infinity or the Comfortmaker ION. I am having trouble deciding which way to go and would appreciate any expertise you can provide with if there would be any differences other than possibly cosmetic as from what I can see the specs look identical and the Carrier is running $xxxx more for the complete job for install than the Comfortmaker. Both carry the same 10 yr parts warranty if registered in 90 days and both contractors give a 5 year labor warranty which both confirmed does not include refrigerant. Both have also said they will include a surge protector in the 220 electrical shut off box on the outside of the house.
Carrier® Infinity® - 4 Ton 19 SEER Residential Variable Speed Air Conditioner Condensing Unit
Carrier 4 Ton Evaporator V Coil Cased Upflow / Downflow Painted 21" Width Model: CVPVA4821XMC
Carrier® Infinity® 97% AFUE 100000 Btuh Modulating, 4-Way Multipoise, High Efficiency, Condensing Gas Furnace model: 59MN7C100C21--22
Carrier® - Infinity® System Control with Wi-Fi® Remote Access SYSTXCCITC01-B System Control
OR
Comfortmaker CVA9 Ion™ Variable-Speed Air Conditioner
Comfortmaker EVD4X Performance Cased V Evaporator Coil with Power-V Technology
Comfortmaker Ion™ G97CMN 98 Variable-Speed Modulating Gas Furnace
Comfortmaker SYST0101CW Ion™ System control
OR
