1 - 1 of 6 Posts
It’s done the way you like all day, every day. A modulating furnace will require zoning to work best. This is because as the furnace ramps down in capacity so does the airflow. This can cause rooms farthest from the furnace to not have enough velocity to keep the room comfortable. If your primarily going to be using heat then returns on the floor will be more comfortable, but it’s your house
1 - 1 of 6 Posts
