Have a Housewise t6-wem thermostat . I am super frustrated I can't figure out where setpoint is to switch me from heat pump to gas at a certain temperature . please help thanks,
Bryant Housewise t6-wem thermostat how do I do setpoint for hybrid furnace
Do you know this for sure I have looked everywhere is this on a secret menu or something. I asked the installer they said it's a newer thermostat and that it kicks in the aux heat that is gas that the thermostat does it automatically but I don't buy that and I want to control the temperature of when it goes from heat pump to propane . They said they would look at documentation and get back with me but haven't yet? Are you familiar with this thermostat ?
I finally found dealer documentation. I have it set to 35 degrees now. I won't share how to get into the menu because if you change the wrong settings well you can hurt your system.
30 or even 25 might be better. Varies with what you pay for electric and for gas. Around here, if the heat pump can handle the load, 25 works out as a better temp.
Related Threads
HVAC-Talk: Heating, Air & Refrigeration Discussion
