Approach temps are very valuable troubleshooting methods. As far as bulletins, much like the others said more rules of thumb. Get the original start-up & spec sheets from the manufacturer or the building owners (if they have it). This will tell you what the machine was ORGINALLY designed for deltas, approach, GPM, kw, etc. You can compare this to what you are reading now. Chances are, if its an older bldg, there could have been load changes & renovations, hopefully the machine can keep up.
Also keep in mind the number of passes your barrel has 1,2,3,or 4. The longer the water is contact w/ the tubes the lower your approach will be. 3 & 4 pass barrels are more on the evap side (flooded chillers), however there are also 3 pass condensers. If you have a wide approach on a 2 pass barrel the less heat exchange is happening, gpm & load both affect approach temps. As well as, overall chiller mtc, tube brushing, proper charge, leaks,oil charge & return etc. Also building mtc men can affect the approach & overall machine performance.
