Hey all, I'm currently designing a home (almost done with structural engineering) in Florida and need some advice. I'd like to hang the air handler from the ceiling, inside conditioned space and build a dog house around it. I was wondering for horizontal setup:
1. Are there any options on how to connect the supply/return? Blower positioned to face up? Using side and top inlets?
Either my supply or return with have to make a 180° turn (I'll try to be gentle). I've seen return plenums split and run through the side and bottom for upflows. I like the idea of reduced static pressure, plus running 2 filters (4-5", one for side intake, another for bottom, obviously not 2 stacked back to back) would require less swapping out.
2. How much space would a technician want to see around the unit? Any space needed on bottom?
Space is fairly limited, but I figure I can get a 24"x50" unit in with about 15" on each side and maybe 12-18" vertically. I would like it to be reasonably easy to install/ service.
Any advice is appreciated.
