I have a horizontal furnace and AC on a second floor - there's finished living space underneath.
Original installer did not put a drain pan in or a secondary drain. Just primary gravity drains for furnace and AC.
I think it should have a drain pan and secondary drain.
The furnace is sitting on two cinder blocks on plywood floor.
Any suggestions are how I can get a drain pan under there now? Can the furnace/blocks be lifted slightly to shimmy a pan under there, without disconnecting things etc.? The gas line is flexible but the vents are rigid PVC.
Thanks!
Thanks!
