One of my 9 year old AC condensing units developed a new issue in which, when it’s mid 80s or warmer, the compressor motor doesn’t turn on for 25 minutes or more. This started happening after an HVAC tech added a slight amount of r410a to both zones this past Monday. Now, for one of the zones, when the thermostat calls for cooling, the fan inside the condensing unit turns on immediately but the actual compressor motor does not turn on immediately under these warmer conditions. Once it does eventually come on, after at least 25 minutes of delay, it’s sudden and cools well until the end of the cycle when the thermostat stops calling for cooling.
This past Monday, an HVAC tech came over because I had noticed some type of high-pitched whistling noise on warmer days in this same zone, where the liquid line enters the metal plenum housing for the evaporator coils above the furnace for that zone. It was only noticeable if you’re standing right in front of the liquid line. I also noticed that some condensation forming quickly on the side of that metal plenum housing when it ran, but not enough to drip. He added a little bit of r410a, less than a pound, and said he didn’t really think there was a leak but that the small increase should improve things. It did improve the cooling and I no longer hear the whistling type of sound on warmer days, or see any condensation on side of metal housing for evaporator coils, when it is actually running but now there’s an annoying delayed start on warmer afternoons and I’m wondering why.
I do have a call into the tech, but I’m wondering what your thoughts are on what the issue is now. It’s a nine year old FirstCo unit and works like an ordinary standard outside condenser except it is mounted though the wall of our outside closet off the deck. Wondering why this is happening now on warmer afternoons and what’s the cause? It wasn’t happening until the tech added a little bit of refrigerant, which did improve the cooling when it’s actually running.
Thanks,
j.
Thanks,
j.
