Sent to another commercial maintenance we never been to.
Pulled up and was happy at first. Thought I was going to have a good time working on some RTU's on this roof.
WRONG!!!
A damn SPLIT system. Notice the company (a local commercial A/C company initials P.A.) installed this new system. Note the 20+ yr old disconnect?
But first I like to do the air handlers.
I got to go up there???
Way up there. And not much to stand on. It's right above a steel framed wall. So the ladder can't go under the unit.
The only thing to step on is the top of this wall.
A 7 1/2 ton trane. Hard to get up in there. I HATE t-grid jobs in Phoenix!
Another view of the steel wall which is ALL you have to stand on.
I had a little more access on this side.
Them jack ass' installed the secondary pan all crooked. It's not even as wide as the unit. and the drain is in the MIDDLE not the corner of the pan. So you know that biatch will fill with water then buckle before it ever drains!
and like the condenser unit. They went through all the trouble to re install the OLD ASS disconnect!
they used seal tight out the bottom to go to the heat strips in the supply plenum. but just pulled the three wires out this side and into a hole of the side of the A/H for the blower!
Oh yeah. and it's been leaking water each summer.
Yeah. it's 1/4 inch out in just 6 inches! So it was sagging about an inch or more towards the side without the drain. I tried to re level it,
... but it wasn't working. that wasn't enough!
So I yanked out that drain and moved the outlet to the other side. Might as well use the side it's pitched towards.
Dumb Shits.
