1 - 10 of 10 Posts
TheClimatemaster
· Registered
Joined
Discussion starter · #1 ·
Im a maintenance supervisor for a 208 unit multi family housing community. I have a Heil air handler that will blow the 24 v fuse after being in cool mode for about 10 minutes. I have changed the contactor and inspected 24 v lines to condensing unit. I don't understand why it doesn't blow immediately. Any ideas?
Intermittent short. If you have verified it's not the cabling. Check the thermostat.
When in doubt, ohm it out.
Save
Discussion starter · #4 ·
Thanks for your responses
After lunch I ran a new 24v line. Think it solved the problem. Dr. Phil anybody can call somebody, I didn't get were I am by doing that. Why call someone that is simply going to go through the same steps in which I would? Shorts and grounds just take a bit of patience and time.
Unfortunately, we can't go into depth with you yet. If you get your count up and are indeed a pro, we can go through procedures with you. Finding low voltage intermittant shorts can be a pain. Sometimes when you change something out, you move the actual short a little bit and it shows back up. I hope you got it.
So how do you get "pro" status on here? I did what I was supposed to and haven't received an answer about 3 weeks later. I would like to discuss commercial/industrial HVAC issues but can't. What's up with this? I'm not sure who to ask on here. Any ideas?
I don't know man. I wish I could share more, but rules are ...
Personally, I would e-mail Lusker. He'll get back to you.
1 - 10 of 10 Posts
