Alright, so the 8+ old year R22 evaporator coil leaked right on schedule, R22 appears to be too risky for only a new coil (in terms of benefits/cost). The house has 2 units, so can mitigate 1 unit failure for a few days (but the full comfort is not there ...).
20+ year old Copeland scroll compressor in the Carrier is probably fine (hard start kit seemed to be doing a fine job!), but not sure it'd last another coil lifetime (~8-9 years), plus R22 costs (even if the cheapest tank from internet).
Location: southeast TX, so the AC is pretty much on all the time May-Oct, mostly off Nov-Apr. Gas furnace and AC coil are totally separate sub-systems, can swap either whenever. Electricity costs are ~9.5 cents if in bulk (~2000 kWh).
Current thinking - replace compressor/evaporator coil to get it to R410A (most simple hardware config, to ensure longevity), keep the furnace while it runs. Mostly likely the next repair would still be the R410a evaporator coil (not the furnace). R410a pressure is higher, so the leak will occur sooner.
I am crunching the numbers here, don't see a more sensible path forward. R410a is a necessary evil at this point, but the gas furnace gets too limited use, so let it be while it lasts. The blower motor is dumb (simple), if it fails, just swap it.
Other thoughts?
Other thoughts?
