Goodman Heat Pump Thermostat Wiring
31K views 13 replies 6 participants last post by  beenthere
#1 ·
I recently bought a 10yr old residential condo in a walkup building of 4 units. My unit is a 950sqft 1br unit with a Goodman ARUF024-00A-1 all electric heat pump installed. the thermostat in the house did not have an emergency setting, and before closing we had the owners hire a professional to install a heat pump thermostat with aux option (Honeywell model TH3210D)
The last 2 weeks it has been quite cold here in Philadelphia and while heat is definitely coming out of the vents, some vents do not seem to be very warm. I took the thermostat case off the wall to look at the wiring and am questioning the installation. I posted a picture of the wiring and was wondering if anyone knows if this looks familiar to them. My suspicion is on the red jumper from E to AUX.
Does anyone have advice as to if this is possibly correct, or should I higher a professional to correct any issues.
Thanks for any advice
#3 ·
If you have heat coming out, but not as warm at some registers, it's not the thermostat.
Call the guy who already got paid for the job.
Save
#5 ·
Also the black wire is not connected to anything, and there is a brown while coiled up behind other wires also not connected. I have some novice wiring experience and as far as i know black is usually hot, so what could that be?
#8 ·
More than likely, the installer didn't mark the panel with which heat kit he installed.
Take a picture of the high voltage wiring going into the furnace. Don't take any doors off.
Save
#10 ·
Looks big enough to me for you to have a heat kit in it. You probably do.
Save
#12 ·
Sounds like your all setup.
Sounds like you have more of a duct issue.
Save
#13 · (Edited)
You have a 8 wire bundle wire and need only 6 wires the other 2 wires are spares. As far as the E ( emergency ) Auxiliary jumper with the white wire looks correct to me. They even used the correct colors going to terminals . Goodman for the most part uses blue colored wires for the C . The white wire goes to your electric heat relay . During normal operation the heat pump is first stage heat through Y , 2nd stage heat is through the AUX./E , during emergency heat mode you power your electric heat through the E/AUX. If you feel cooler air from some vents than others may be due to those vents are furthest from the air handler , loosing temperature before they come out of the vents.
Save
