is ok not to discharge a dual capacitor before replacing it? it was mentioned (i forgot were)that since main power to outside unit was turned off already, capacitor will discharge by itself.
This is the truthIt will disharge by itself provided it is still properly connected to the motor.
This has been my experience.It will disharge by itself provided it is still properly connected to the motor.
If a wire happened to come off one of the terminals while the unit was in operation the cap will still be holding a charge even if all power is disconnected.
It has happened!
Best to attempt to discharge just to be safe.
I've seen it happen. I like your thinking though, I've never seen anybody get hit running a 4-way stop sign either.Start capacitors with high microfarads normally have a bleed resistor across the top of them to discharge themselves. I have never been zapped by a run capacitor and I dont think that its possible to get hit by one because it would have happened to me by now.
Then you just been lucky.Start capacitors with high microfarads normally have a bleed resistor across the top of them to discharge themselves. I have never been zapped by a run capacitor and I dont think that its possible to get hit by one because it would have happened to me by now.
LOL....It hasn't happened to me so it cant happen. Good thinkin. How hard is it to stick a screw driver across the terminals to make sure.I have had plenty of them discharge when doing this. You keep thinking that and I guarantee you will get hit.Start capacitors with high microfarads normally have a bleed resistor across the top of them to discharge themselves. I have never been zapped by a run capacitor and I dont think that its possible to get hit by one because it would have happened to me by now.
This guy has some interesting videos. Does anyone know if he's a member of this forum?
I always check with a needle nose because it sucks getting zapped!:troll2:is ok not to discharge a dual capacitor before replacing it? it was mentioned (i forgot were)that since main power to outside unit was turned off already, capacitor will discharge by itself.
If it doesn't kill you!!I guess if you feel more comfortable discharging them then why not?
I will start discharging them the day I get bit by one.
