Has anybody encountered this coil yet? Thoughts?
I do believe Heatcraft recommend some sort of epoxy for repairing the aluminum coilI do imagine they would be a mofo to try and repair if it is in the coil itself.
My concern with this is how long does the epoxy take to cure? Its fine to shut down a comfort cooling system overnight to let epoxy cure, but thats not gonna fly with refrigeration.I do believe Heatcraft recommend some sort of epoxy for repairing the aluminum coil
Mike
Follow the link that MikeySq posted on the previous link. You'll get your answer.I installed a Bohn cond. unit with the microchannel coil. It had no tag on how much refrig. to add to flood the cond. Sure can't use the old method of calculating the length of tubing. I added about 15% more and will have to check when the cold weather sets in . Any Ideas ???:anyone:
