1 - 9 of 9 Posts
wikid321
· Registered
Joined
Discussion starter · #1 ·
I had this issue once before were compressor outside spins but only fan blwong inside not cold air at all. The guy who installed it said look at your filter which i did was aliitle dirty let unit sit for a bit then turned it on and worked. So i replaced filter. Today same issue but filter isnt that dirty i dont think. I did samething but he also mentioned run it without the filter for a bit which i did. Did this for 30 minutes put filter back in. Two hours later same issue new filter no cold air.. Left it off for 15 minutes back up again. Any suggestions. I have a one month old and ac guys cant be out till saturday.
Discussion starter · #4 ·
Thanks guy i've tried all that. I have a contract with pseg and there the ones who can only come out saturday... Everyone else are way to busy. Its 90 degrees up this way so every ac unit is breaking. My question is there anything i can do or is this normal just let it run for a bit without the filter. My whole unit is only 2 yrs old with compressor.
Discussion starter · #7 ·
also any suggestions on what it might be so i dont have some guy here saying u need a new compressor.. because pseg guys only know so much then its like ah ur gonna need new stuff..
Since we aren't there to check it to know what it is.
Suggestions from us, could make it take longer for them to find the real problem. Since they might just follow the advise. And not look for the real problem then. And you could end up waiting 2 more days for them to come back out.
1 - 9 of 9 Posts
