I have a 13 year old Lennox heat pump in nothwestern Iowa. Recently, Ive replaced the blower motor and a defrost board. This has me thinking about what will fail next and thinking of its eventual replacement. I am also hearing 410A will be a thing of the past. Due to the nature of the install in my home, replacing the air handler and line set would add some complexity. My air handler is electric backup and with the blower motor replaced, the only other failure point is the board or the heat strips. My thought was to just replace the evaporator and condenser coil. I contacted the dealer that installed the original and he somewhat agreed with my thought process. He spec'd me out a new 3 ton A coil and 3 ton condenser, still single stage. Existing coil and condenser are 2.5 ton but the system seems to struggle on the heating side of things, even in moderate weather. The quote came back quite a bit higher than I expected for just replacing the A coil and condenser. He also quoted me a complete new unit with variable everything. Only about *** more than reusing my existing air handler.
So here is where I'm at: spending **** to replace a unit that is at this point, functioning fine, seems foolish. If I wait, and the unit fails, I will be looking at higher equipment cost and higher install costs. I've also not been a huge fan of lennox or the install of the existing unit. There were lots of problems early on with the unit and I feel it has never really performed great.
My options as I see it:
Go with the replacement lennox components.
See if another company can fit another brand A coil and condenser into my existing air handler.
Wait until the next major failure and deal with it then.
Some other relavent info:
The home is half earth home, half above grade. The earth home portion of the home is very easy to cool but hard to heat. The above grade portion is spray foamed with lots of attic insulation. The earth home portion has electric baseboards that have gone unused since installing the heat pump. We have tiered electrical rates. The more you use, the cheaper the rate gets. for this reason, I often question if the heat pump is even worth it. Due to the type of home and the climate of nothwest Iowa, the heat pump really only operates in Nov, Feb, March and part of Apr. Dec and Jan are usually too cold, and we are operating on electric backup.
Any suggestions are greatly appreciated.
Please do not add pricing to your posts as it is not allowed by forum rules - thanks.
