1 - 19 of 19 Posts
Frankelly12
· Registered
Joined
Discussion starter · #1 ·
Hello, good afternoon. I am an Hvac tech and I had a quick question about doing jobs on the side and (or) getting contracts with a company for maintenance. Could you do that without a contractors license?
Because your profile states you are a tech, I moved your thread to the “General Discussion” forum. The AOP Residential HVAC forum is where homeowners can ask non technical questions.
Please take note of this new location as the "Moved" icon in the other forum will only last a day.
Save
Check with state/local authority. Varies from state to state. Typically any contract or equipment installation requires license.
Depends on the state you live in. I think most will allow you to work on "refrigeration" like coolers and freezers and stoves or grills or deep fryers etc ....without a special state license , but when it comes to HVAC you have to be qualified through the state exams
Save
Yeah, it's going to depend on which state you're in. Most states have some sort of licensing for HVAC, many also apply to refrigeration. But the rules are all different. EX: In Georgia, you need a license for HVAC, but not refrigeration. In Alabama, you need a license for both (and they are separate licenses), and an HVAC license is required even to change filters or do maintenance.
If you would like to share which state you're in, we might could better advise you.
In California it used to be okay to do service work without a contractors license, you just could not give a quote (a contract), you had to work by the hour and the work could not exceed $600. I think that limit has been raised to $900. You do need to get a city license from every city you are going to be working in, it is basically a handyman's license. Then, of course, you'd need to follow all of the Federal EPA regulations.
Save
I'm in Texas. Here you must have a contractors license for both AC & Refrigeration service or installation & employees need a Tech license in most cases. We do have a combination which is what I carry.
Now when I was still in business and if I found an employee doing side work, I'd fire them right then & there no matter how behind we were and I did once. I paid well and and had enough work a tech could work extra hours if they needed/wantedthe money
Kinda funny you say this. I did one side job after I first got in the trade, it was for a friend of the owner, and as a courtesy recommended by the owner.
Then for the next 40+ years I refused ALL side work. Except for my immediate nieghbors where I live. And even that was only for simple fast repairs or to just give the diagnoses so they wouldn't get ripped off by a mis-diagnoses.
Save
Technically you need State and local licenses, insurance, etc to legally do HVAC work. You can't pull a permit anywhere without all that. If you're going to go get all those licenses and such you may as well start your own company.
The point of side work is the homeowner gets a lower price because you're not paying all these fees and costs. Side jobbers don't pull permits or get inspections. The only way the city finds out is if you leave the old stuff on the curb or someone dimes you out. The risk in this is that if there's a major problem you are probably going to be personally liable.
Save
In Minnesota, you need insurance, gas and refrigeration cards (licenses) in the large metro areas. Minneapolis, St. Paul, Rochester, Duluth mainly. In the rural areas all you need is general liability insurance to pull a permit.
Save
I've been doing HVAC side jobs for a couple of years now. Technically, it depends on your state laws, but many places require a contractor's license for any work beyond minor repairs or maintenance. I'd recommend getting your license if you're planning to take on larger projects or want to avoid potential legal issues. It also boosts your credibility with clients!
Thansin, Here in Florida anyone who wants to start their own Plumbing business can do so by being "Qualified" by a Licensed Contractor. I am a Certified Florida Plumbing Contractor and I can do that for you. Feel free to contact me at xxxxxxx
I removed your email address. Site policy is that your address belongs in your profile. It can be accessed there by other members.
Save
You can pull all day long in Illinois. None of that is needed here.
Not quite true....
Illinois does not require entry to mid-level HVAC professionals to obtain licensure prior to entering the workforce. However, the state does require HVAC contractors to obtain licensure at the city or county level prior to completing work. Different cities and localities may set their own HVAC licensing regulations and some require HVAC professionals to obtain a general contractor license instead of an HVAC specific contractor license.
HVAC professionals are typically required to obtain a contractor license when projects surpass $1,000. Usually, HVAC contractors must obtain a business license along with liability insurance and a surety bond. Additionally, it is generally required to have a credit check and pass an applicable exam related to contractor’s field of work.
Illinois HVAC License Options
In most cases, HVAC professionals working in Illinois will need to obtain either a general contractor license or a HVAC specific contractor license where applicable. Cities, such as Chicago, have multiple contractor license classifications available including Class A, Class B, Class C, Class D, and Class E which are based on the overall value of a project. Class A licensure allows HVAC contractors to work on projects of all values and has no monetary limit. Class B licensure limits HVAC contractors to working on projects worth up to $10,000,000. Class C licensure limits HVAC contractors to working on projects worth up to $5,000,000. Class D licensure limits HVAC contractors to working on projects worth up to $2,000,000. Class E licensure limits HVAC contractors to working on projects worth up to $500,000. The fees associated for each classification are $2000, $1000, $750, $500, and $300 respectively.
Not so fast. Your second sentence is specious, since there is no such thing as an HVAC contractor license in Illinois, and none at the city or county level either. A lot of HVAC dealers like to add licensing wording to their site to discourage DIY, but there is no such requirement by the state.
Reflecting the OPs post, The STATE requires nothing. A very few cities may request a contractor license in order to get a permit, but when rarely required, will waive it in most cases and certainly for the homeowner.
It is easy to get confused, and it is truly odd, since this is one state where Union representation is high, Flex is rare and things like Electrical in conduit, is the mandate in many counties. But no HVAC nor Gas License is required. Guess that makes THIS the Freedom State ;-)
"Not so fast. Your second sentence is specious, since there is no such thing as an HVAC contractor license in Illinois, and none at the city or county level either. A lot of HVAC dealers like to add licensing wording to their site to discourage DIY, but there is no such requirement by the state.
It is easy to get confused, and it is truly odd, since this is one state where Union representation is high, Flex is rare and things like Electrical in conduit, is the mandate in many counties. But no HVAC nor Gas License is required. Guess that makes THIS the Freedom State ;-)"
Copyright © 2024 HVACCertification.Org. All rights reserved.
Assumed they knew more about it that average tech
1 - 19 of 19 Posts
