Hi,
I have a new mini-split installed for the upstairs and when in heat mode it controls both heads at +6 above the setpoints.
In AC mode it controls temperature just fine. This problem only exists in heat mode :-(
The heat pump is a 3MXS24RMVJUA and one of the heads in 9K BTU and the other is 12K BTU
Daikin tried to blame it on the WiFi but that can be disconnected and the problem remains...
Here's a link to a guy with the same problem last year: (cant post links? - Search "Daiken Temperature Offset")
/hvac-talk.---/vbb/threads/2244114-Daikin-temperature-offset
This system(s) is sitting there reporting the correct room temperature and yet it controls at 6 degrees off the setpoint!
You couldn't design a system with a stupider failure mode!!!! Nice going Daikin!!
Thanks!
Thanks!
