I have a customer that put in a fancy lighting system about 5 years ago - the entire system is obsolete, cannot get parts, and the manufacturer says they have to rip out pretty much everything for a cost of over 200k.... They are not excited about that.
So they are VERY motivated to get something that they will not have to replace in 5 years. They will literally take anything. So.... I want to use an off the shelf BAS controller and some RIB Track mounted relays. Why? The form factor on the Track mount relays has not changed in decades, they have HOAs on them, even a child can make the lights come on if they want. No dimmers anywhere this time.
https://www.supplyhouse.com/Functio...6-Track-Mount-Pilot-Relays-15-Amp-SPST-Override-with-24-VAC-DC-Coil-Four-Relays
Not saying this is the exact part, just saying this is where I am leaning. I need to size to the load and such. I may take rail mounted so I can get more options on amperage and such. I know they need to be oversized a little as the load is reactive. I remember that from a long time ago.... I may need to brush up on that.
The question is - is there some kind of code that says I cannot do this? I normally see pulse to open/close - or relays that stay where they are when the controls go down. Is that a requirement? Making sure my 'outside the box' idea on this is not too far outside that box and is still legal.
TIA
TIA
