I'm looking at a mini-split unit for a 150 sq foot building. On the spec sheet it states:
Cooling Capacity (range)| Btu/h 9000 | (3600-10300)
Heating Capacity (range)| Btu/h 10000 | (3500-10900)
Application area (cooling standard) | sq.ft | 100-450
When I have this installed, will the contractor manually modify the BTUs to ~6,000, or will the system automatically adjust based on heat/humidty, etc?
System: Senville SENL-09CD
Thank you,
Thank you,
