I have a two story house, about 2700 square feet and I'd like to reduce the humidity, which is mostly a problem on the 2nd floor. My home has two air handlers, one for each floor, and there is a large opening between the 1st and 2nd floor at the foyer. I'm curious what's the best practice with dehumidifier installation, assuming I went with an ultra-aire 98h or 120h and also took advantage of the fresh air supply as well. Connect the dehumidifier to the 2nd floor unit where I have the highest humidity, or connect the dehumidifier to both air handlers?
