I apologize in advance for the long story. When we moved into our home 30 years ago, it had gas fired hot water baseboard heat and no air conditioning. I wanted air conditioning. Our domestic water supply is from a well that has 12 psi natural pressure at ground level, and a water temperature is 52-deg F. I added a secondary tap off the well casing, and ran an 1.25" line into the house. I purchased two coils that were designed for chilled water, and I have successfully used this to cool my 3800 square foot home for 30 years. It is getting to be time to replace the air handlers and the coils and there are several design issues I wanted to fix.
1. While this systems cools well, it does not reduce the humidity enough. The delta temp at the coil is not high enough.
2. Because this was a retrofit project, I ended up putting one cooling coil in the attic to support the second floor cooling. I have always worried about having water leaking in the attic, and that I have to blow the water out of the lines in the winter. So my preference is to switch to refrigerant based cooling instead of water.
My question is, do they make residential HVAC systems where I could use a water based heat ex-changer instead of air to cool the condenser unit. This would enable me to use a much smaller compressor, and be able to run the coolant cycle at lower pressures and temperatures. Everyone wants to sell me a full blown heat pump, which I don't think I need. I have seen a "This Old House" episode where they used the swimming pool water and a heat ex-changer to cool/condense the refrigerant, but I have not be able to find a manufacturer willing to explore this.
thanks in advance for the help!
