I have a 5 ton system that is short cycling through the low pressure switch. Air coming out of the condenser gets hot then cools constantly and the liquid line get really hot. Restricted TXV?
Your in over your head!The temp oc the air coming out of the condenser goes from 125 to about 148
I base my reply’s on the info given. In this case ......absolutely Zero.Sounds like a vibration that comes and goes I don't know how else to describe it
I'm cleaning the condenser was the first thing I did
Then you’ve done all you can. Time to call for service!And cleaning the condenser was the first thing I did.
I’m trying to keep a DIY from damaging equipment or hurting himself or others butplease dont if you dont want to help cool. but leave me alone and stay off of my post.
