First off I do forced air systems and this is for my personal shop/office I wouldn’t venture into this for a customer.
So here is what I have:
-zone one-First floor in slab radiant heat (shop area) 4-300’ loops to manifold
-zone two- First floor in slab radiant heat (garage area) 3-300’ loops to manifold
-zone 3- Second floor forced air unit with hydronic
Coil.
I am using an air-to-water heat pump and want to use an electric hot water tank for storage/auxiliary heat.
Not sure if I should use one large pump and zone valves or if each zone should have it’s own pump?
I also didn’t know about some of the new hydronic pumps out there that are variable speed. I know what my head loss and gpm requirements are for each zone just now sure how to put it all together.
Coil.
